Results 1 to 8 of 8
Thread: interior doors
    May 2014
    Default interior doors
    would like to ask the best way to patch a hole that the door stop put through both sides of the bath room interior door.
    Oct 2012
    Houston, TX
    318
    Default Re: interior doors
    there was a recent thread about this, do a quick search and you will likely find it
    The repair is called door replacement. For the time and hassles and finished product, it's not worth trying to patch, just replace the door slab. I'd also recommend replacing the doorstop to a spring style and mounting it on the door where it will contact the baseboard. A hinge style doorstop will work as well, but these are extremely hard on the hinge and door, especially in a household with kids.
    Maryland
    2,009
    I tend to like the round, cushioned wall mounted stops that contact the door knob.
    Assuming a hollow core door, if you use the same stop, position it so it contacts near the door edge where there is solid wood. That may only be an inch or so at the bottom and side.
    While I understand what Spruce suggests, not everyone is capable replacing a door. As a landlord, I'm familiar with these problems, holes, scratches, nails, picture hangers - door holes can be repaired the same way as holes in the drywall, with mesh, mud, primer and paint. Material cost: negligible, and your time: a few minutes a day for 3-4 days.
    Quote Originally Posted by ed21 View Post
    Unfortunately, I've seen plenty of "knob stops" shoved through the wall, even with lightweight, hollow core, interior doors. The only time these really work is if the knob stop happens to land on a stud.
    You're not allowed to disagree! LOL I see the OP was able to overcome the problem with ed's suggestion. Accidents happen, let's hope momma stays safe.
    May 2014
    ed21
    you got the best solution , I went to home depot got two of them and placed one both sides of the door to cover the holes total cost was only $6.36 and to boot the color matched as well. thank you for your out put this was sure cheaper then replacing the door . my mother is handicap and she fell onto the door causing this to happen.
    Maryland
    2,009
    Quote Originally Posted by atfencing View Post
    ed21
    Well that was thinking outside the box.
    A quick story about those springy door stops with the rubber tip. When my oldest daughter was about two her mother screamed for me to come. My daughter had a funny look on her face and mom said she just swallowed something. As I opened her mouth I saw the white rubber tip lodged in her throat. It took me a few tries, but I was finally able to get my finger behind it and pull it out. Probably not the recommended thing to do, but it worked. I didn't have time to be scared until it was over.
    She's getting married this summer.
