    May 2009
    Calumet, MI - USA
    Default Triangle Tube vs Crown
    I have 11 cast-iron radiators on a 2 story house built in 1909. I have purchased a Crown AWI095 (spark ign) and an W-M indirect tank (36 gal). I plan on also installing an Intellicon-HW+.
    Now with the new "energy" credit I could consider installing the Triangle Solo 110.
    I have created a program (spreadsheet) to get the bottom-line in regards to updating, or not, existing boilers while considering efficiency, heating loss, cost, rate-of-return, inflation, and life-cycle of the product including future replacements.
    When not considering the energy credit, the mid-efficiency boiler is a better buy because of the high price of a mod-con. Hence the Crown purchase.
    Using the credit, the mod-con is a little better - $1,000+ better return in 15 years.
    So here is the dilema: how much more does it cost to service/fix a mod-con? The technology is only about 15 years old; has any stainless mod-con boiler even reached the end of it's life?
    It would also cost more to replace the boiler after 15/20 years. I also live in a very, very cold area (49913) and need my basement temp to be bearable during the winter.
    What to do?
    Is an Intellicon really worth it? I am leaning towards the Crown (since I already purchased it) with the Intellicon because the tried-n-tru "standard" technology and less costly maintenance and part replacement.
    566
    Default Re: Triangle Tube vs Crown
    drillbody:
    I think you made an excellent choice & should stick with it.
    Crown makes excellent products and the Aruba is their largest selling unit---not too familiar with the intellicon, but I'm sure it will help you save fuel.
    I've always been big on Crown & the indirect is another wise choice---best of luck with the new unit.
