    Apr 2014
    Default What's the best way to raise height of Kitchen Island cabinets
    The previous homeowner used her kitchen island as a desk so the base cabinets are at desk height and not the standard countertop height.
    We are doing up updates to the kitchen and have decided to make the kitchen more open to the dining and living room. We have left the bottom half of the wall to minimize re-routing of ductwork and electrical. The half wall will be 34.5 inches and the plan is to put granite on top of that.
    My question is whatís the best way to raise the height of the islandís base cabinets? The cabinets will need to be raised 3-4 inches. I did remove some upper cabinets and could use some that that to create a trim piece to be screwed/glued to the top of the base cabinets. My thought was to use glue and pocket screws to attach to the top of the existing cabinets.
    I feel if I were to build up a base platform the toe kick would be way to high and look goofy.
    Sorry for the bad picture but you should be able to see the height difference between the existing counter and where the top of the wall will be once we finish it.
    Attached Files Attached Files
    Maryland
    1,723
    Default Re: What's the best way to raise height of Kitchen Island cabinets
    Sounds like a plan. The granite top will need additional support. Sleepers on the existing cabinets or counter will work.
    6,767
    The photo is so unclear.
    5,846
    How about installing dividers and adding a couple of drawers in the space?
    Maryland
    1,723
    I like adding drawers if you can match the cabinets well enough.
    Dec 2013
    Iowa
    222
    I saw this picture and it reminded me of your problem. If you make a shelf, but don't want to do drawers, baskets might work. Baskets come in all sorts of hights and sizes and are made from straw, canvas and other materials.
    http://s514.photobucket.com/user/jhm...tml?sort=3&o=0
    Jul 2009
    Washington state
    206
    It looks like a shallow utensil drawer would work there. Or a slide out tray or cutting board. If you can't match the cabinet wood, you could use a contrasting color or tile.
