Thread: What is it?
    May 2007
    188
    Default What is it?
    Do you know what this tool is? We're stumped!
    Gilbert A. in Garland, Texas writes:
    I watch TOH religiously and I have run into this tool at a flea market, but no one seems to know what it is . I work in the maintenance department for a manufacturing plant and none of the guys can seem to pinpoint the tool's use. Your help would be greatly appreciated!
    7,869
    Default Re: What is it?
    What I see is a clamp (black thumb screw on right side ) with a handle on the left that moves a cranked shaft up and down.. The cranked shaft has what looks like carbide/diamond cutter, possibly adjustable for different diameter holes. My guess is that this is used to cut round holes in tile before setting, or faucet holes in a granite counter top. I'm pretty certain that this is a carbide/diamond cutter for cutting masonry products, but just WHAT its purpose is, I am not sure.
    Sand Springs, OK
    467
    I would think it's a hole cutter or scribe. Either that black bar rests on the edge or on a pipe depending if it's flat or if it's cupped or which way it's cupped.
    Debby in Oklahoma
    Shamokin, Pa.
    645
    I think it is a beer bottle capper.
    Jan 2009
    Needham, MA
    559
    can i borrow it? i have to drill some sense into my wife
    May 2009
    it looks like a caulking gun or something
    Looks like it might be a means to tap a hole in the sidewall of pipe or the underside of a handrail for stiles. Manual crank driving power and a curved clamp/vice with a spring for setting in place before operating the crank like a drill press. Might be missing some U bolts,straps, or something similar to hold the tapping/drilling tool to the item being tapped.
    If its not missing any thing might be a tool for boring a door blank for a lockset or pulling a cylinder from one. I'd investigate locksmith/safe tools first.
