    Apr 2014
    Question ceiling - spray ceiling
    I have spray ceilings - guess it called Popcorn ceiling. thinking it was done when house was built. around lights and edge of ceilings it is starting to crack and around my ceiling fan it is hanging. is there an easy way to get it down without too much trouble and mess
    hope someone can help.
    Default Re: ceiling - spray ceiling
    Removing popcorn is relatively easy, but it's messy. Better have the house vacant. In most cases the drywall will need finishing as well.
    What you don't want to do is paint over the dirty areas.
    Shop around for contractors, get references and check them carefully. If you want to do it yourself, be prepared for the mess.
    You should also assume that there is asbestos, while many of us don't believe that this the harbinger of death that it's made out to be, it still warrants caution and safe handling practices. Having it tested is a personal call, homes build post 1978 are less likely to have asbestos products, but it is still possible.
    The easiest way to remove it is to clear the room of furniture, tarp the floor with painters plastic that is taped at all seams and around the perimeter to the wall. Use a garden sprayer of water to dampen and soften the popcorn, then use a scra-per or drywall knife to remove it. When you're finished, simply roll the plastic up off the floor, put it into a garbage bag, and toss it. You should wear safety glasses and a good quality dust mask while doing this work.
    Once the texture is down, you can repair the drywall, retexture to your liking, then prime and paint.
    If all you want to do is repair the damaged areas, you can do this too, though the patches may stand out a bit when you're finished. Patching would be best left to professionals or experienced DIYr.
