    Apr 2014
    Default 1/2 cementboard too thick, 1/4 too thin - help!
    Had to tear plaster off behind sink as it was damaged, now I want to install a new backsplash. I am left with a rectangular section of the wall that is the exposed lath. I thought cementboard would be the right kind of backer for the tile, but on top of the lath it is not flush with the plaster next to it. It is about 1/8 inch out of flush. Using 1/4 which isn't recommended for tile makes is -1/8 inch out of flush with the plaster. What's my solution?
    6,015
    Default Re: 1/2 cementboard too thick, 1/4 too thin - help!
    Use " and level with thinset.
    3,158
    For all things tile related, head on over to the John Bridge Tile Forum.
    There you can start a new thread with pictures of your dilemma
    7,762
    OR...
    Install 1/4" plywood or shims on the studs, then attach your CBU.
    Sep 2012
    Boston
    1,002
    BINGO.....dj's solution is what i would do
