Results 1 to 10 of 19
    Apr 2014
    7
    Default Rewire Entire House
    I bought an home built in 1930. It is a complete mess. currently occupied by transients. I am going to gut the whole thing. After I pull all the old plaster off the walls everything will be exposed. I want to run new electrical in the whole house. it is a 2 story ( main floor and a basement with 3 bedrooms)
    What can I expect in terms of cost and time?
    Sep 2012
    Boston
    1,002
    Default Re: Rewire Entire House
    see my answer to your other post.....same answer applies
    1,884
    A million bucks and a hundred years.
    Seriously, there are far too many variables and you haven't provided enough information. How big is the house? How many stories? What is the going rate for electricians in your area? Are you planning to use electric heat or some other fuel source? Are you going to do the work yourself? Too many unknowns to get even an educated guess in an 0nline forum.
    For a 2000 square foot home with gas heat doing the absolute minimum you could spend $3000 just on materials. You could spend double that. You could spend half that. Calling some electricians for estimates will be your best bet, even if you plan to do the work yourself.
    Now if you have any questions on the best way to do something, we can probably help you there.
    Apr 2014
    7
    thank you very much for the replies.
    Jan 2014
    NH
    136
    Hi, If you are going to rewire then I would use #10 wire to keep your electric bill lower, forget about the #14 and #12 wire. Thanks
    6,017
    Quote Originally Posted by MtMan54 View Post
    WHAT??????? The additional cost of the cabling will out cost years and years of savings.
    7,762
    Not to mention the difficulty in working with #10 wires.
    Jan 2014
    NH
    136
    Hi, I will make it easier for you if this is to difficult. Use #10 wires for the first 3/4 of each run and then use #12 wires for the last 1/4 of each run. Will this make you happy? Thanks
    7,762
    Is this how you re-wire homes?
    Jan 2014
    NH
    136
    Hi, If this was not important, then I would not say anything. Thanks
