Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
  1. #11
    1,862
    Default Re: Change bathroom heater from thermostat to on/off switch
    There should be no problem using a timer. I did that in my own bathroom, and it works great.
    You'll probably want to use a 30 minute spring-wound timer -- electronic timers usually aren't rated to handle the load of a heater and may not work correctly on a 240V circuit. The spring-wound timer shouldn't be a problem.
    If your exhaust fan isn't on a timer, it should be. Then when you're done showering or stinking up the bathroom, you can let the fan run a while to clear the air without worrying that you'll forget it on.
