Results 1 to 10 of 11
    Jul 2009
    Washington state
    235
    Default Change bathroom heater from thermostat to on/off switch
    We have a ceiling-mounted heater in one of our bathrooms, circa 1970, that is controlled by a thermostat. The room is usually warmed by ambient air, so the heater is seldom used. We'd like to have a simple on/off switch for those times when a little extra heat is wanted. Can we switch the thermostat out? Or do we need to replace the unit with something else?
    6,063
    Default Re: Change bathroom heater from thermostat to on/off switch
    I wouldn't do it. If you forget that you turned it on you could burn down the house.
    Jan 2014
    NH
    137
    Hi, You need to keep the thermostat but you can add a switch or lower the temp when it is not needed. Is this heater on a separate circuit? Thanks
    Jul 2009
    Washington state
    235
    It's always on the lowest setting. I don't know if it's on a separate circuit but I think not.
    Looks like replacement is the way to go; maybe infrared instead of electric coils.
    Thanks.
    Jan 2011
    Columbiana, Alabama
    843
    Quote Originally Posted by queen60 View Post
    Thanks.
    You say the heater thermostat is on it's lowest setting? Can't you just set it higher?
    Maryland
    2,009
    All thermostats I've seen have an off switch built into them. What happens in the summer when the A/C is on?
    You should be able to replace the thermostat with a new one.
