Results 1 to 8 of 8
    Apr 2014
    Default tile over ksplasha formica bac
    can you put ceramic tile over a formica wall between lower and upper cabinets and what is the process
    994
    Default Re: tile over ksplasha formica bac
    it can be done but it is not recommended. most important thing to determine is if the formica is properly adhered to the wall. if it's the least bit flexible or spongy then i would recommend removing it prior to tiling. if it appears to be nice and tight on the wall, you can purchase a bonding agent at any tile store. you simply paint or roll it on the formica and after it dries, you can tile away.
    2,917
    There is no tiling product that will allow for a decent bond.
    Removing the formica is normally a very easy process
    994
    houston.....yes there is. saw it for the first time about 2 weeks ago and i asked about it. i forget the name but when i go back there i'll post the info on it.
    Dec 2013
    Iowa
    197
    MLB - could it be SimpleMat? I have not used it but HomeDepot has a tutorial using SimpleMat to tile on a mirror. They also said DAP Aquarium Adhesive could also be used on a mirror. Might work on formica? The SimpleMat also will adhere the grout but I don't know about the DAP.
    994
    that's not the stuff i'm thinking about. i wish i took a picture of it or wrote down the name. i'll find out and let you all know.
