Thread: Balance Systems
    Mar 2014
    Default Balance Systems
    Considering window replacement/repair. Is there any balance system which is clearly superior to rest?
    tubular vs tape spring? which is better?
    What should I be considering?
    2,721
    Default Re: Balance Systems
    I generally replace the balances with whatever is already there unless there's an overriding reason not to. It makes the job easier and the repairs should last at least as long as the original balances did. While you're in there you might want to renew any glazing, paint, caulk, and weatherstripping too while you've got everything apart.
    3,188
    I have removed fully functioning 70 year old pulley operated windows. Can't say that for the other types.
    1,383
    And the pulleys have been letting outside air infiltrate for 70 years. The tape/spiral balances were designed to get away from the drafty weight pocket/pulley.
    Not that I don't agree with your point, they are mechanical and wear out within 40-50 years, often less. I still have weights and pulleys on my 1906 windows!
    Casey
    Apr 2014
    I find Constant Force balances don't break unless you set out to break them. Easy operating force up and down, hence the name.
