Results 1 to 10 of 10
    Sep 2007
    178
    Default utility sink does not drain well
    I finally got to install a utility sink I purchased from HD. I say "finally" as it took a while to do all the plumbing, venting, wall build etc. So after all of that I was pretty excited to make the final connections and start using it.
    I even spent a bit more to get something I thought would be nice. Here is the one I bought:
    http://www.homedepot.com/p/Glacier-B...9?N=5yc1vZbqkn
    So the problem is the basin does not drain well. I tried tilting it around ( to make up for not being level) and still could not get the water to all make its way down. I checked the tail piece to make sure I was not pushing up from below making the drain hole higher than the surround surface of the basin. Here are my two guesses
    1. I used putty around the ring at the bottom of the basin. It does not look like I used a crazy amount and most of it did extrude out. Maybe that it causing the ring to sit too far up?
    2. The bottom of the basin has bowed up for whatever reason
    Has anyone experienced this before? I was wondering if I put some weight in the basin and let it sit for a while maybe the shape of the basin would creep into something more like it should look.
    Any help with this would be greatly appreciated.
    -Walt
    Maryland
    2,002
    Default Re: utility sink does not drain well
    Is it possible the drain pipe is pushing upon the sink causing the bottom of the sink to deflect upwards.
    Was the bottom bowed up when you got it. If so it is a defect.
    7,762
    Can you post a picture of under the sink and drain connection.
    1,002
    posting a picture of the drain hook up and where the drain goes into the wall might help.
    i'm guessing, remember i said guessing, that the tee in the wall is up too high. does the top of the trap sit tight against the bottom of the basket strainer? if that's the case you might not have the proper pitch of the waste pipe from the trap to the tee in the wall. this could cause the dink to drain fine until you get to the bottom few inches of water in the sink, then it would drain more slowly and when it's done draining you might have an inch or less of water sitting in the sink. these sinks are deeper than normal so all the in-wall plumbing has to be lowered.
    a picture of this would help
    Sep 2007
    178
    I will put a picture up later today. Just a few comments
    1. I looked at the comments at the HD link to the sink I bought. It would seem this "feature" is a common issue
    2. The drain pipe into the wall is lower the the basin bottom. I think I got that right.
    3. The tail pipe is not pushing up on the bottom of the basin.
    If I am stuck with this sink I was thinking of putting some weight onto the center of the basin and maybe put some heat to the structure. It looks like the basin is cast resin without fibers. I am hoping maybe the flat bottom will "sag" a little bit working in my favor. Does this approach sound silly?
    Dec 2013
    Montreal Canada
    326
    Maybe your drain pipe is partially blocked, or your rough in was too high the correct rough in for a laundry tub is 12 inches off the floor.
    Maryland
    2,002
    It sounds reasonable to me, but I think it's a poorly designed product if that is a common issue. Too bad since it looks like nice utility sink.
    If you heat it with the weight, I would disconnect the drain pipe to allow it to sag. Are you thinking a heat gun that's used for stripping paint? I would be careful, but I doubt a hair dryer would do much, but who knows.
    I might be best to take off the tail piece or at least reset it after the deed is done.
    I'm thinking a couple of 50 pound weights from that weight set in the basement that doesn't get used much anymore would be good.
