    239
    Default Shutters For Twin Double Hung Windows
    The rear window of my home has a twin double hung window with normal size shutters on each side. Obviously there is no function to this since even if they had hinges and weren't purely decorative they couldn't cover the entire width of the window. I wanted to replicate the same look to the front of the house even if it is silly but it got me thinking...are there functional shutters that would be proper for a mulled window and still give the traditional look of shutters? I guess it would have to be some kind of bifold or accordion style in order to be functional but when I search for this I only seem to get results for interior decorative shutters or shutter-style closet doors.
    1,301
    Default Re: Shutters For Twin Double Hung Windows
    Bifold shutters were common for coupled windows.
    Casey
    239
    I dont seem to be getting the expected results when trying to search for bifold shutters. Do they go by a different name or could you maybe suggest a distributor I could buy from? I've also tried searching through local bigbox stores Lowes and Home Depot.
    2,478
    I've seen a number of these in the lower part of my state on 'Plantation houses' near the coast, but the youngest ones were well over 100 years old Something tells me that they were called 'accordion shutters' by the local folks, but don't quote me on that- I ain't been down there in quite some time!
    What I found more amazing is how thin the wood window muntins are on those homes- especially considering the hurricanes they have stood up to through the years- with most being far less than 1/2" wide and about as thick with large paned glass in them. Superb wood knowledge and craftsmanship back then
    7,355
    Maybe Mediterranean style shutters?
    1,301
    Listen,
    You buy the regular wood shutters,total of 1" wider than the opening, and the carpenter rabbets the edges and fits them together with the hinges. The ones I have seen used a special flat hinge with a heavy galvanizing, like the old greenhouse hinges.
    They were surface mounted, not mortised in. The hinges are 95% hidden, and when you close the shutters, they face the glass.
    Casey
