    Mar 2014
    Default 3season room flooring
    I'm building a 3 season rm on existing deck-using current 5/4 pressure treated flooring-Intend to put down 1/2'plywood subfloor for pergo floor .What the best product to use between plywood and deck boards?to keep moisture out-room will have windows.under deck boards-not between deck boards and plywood
    Default Re: 3season room flooring
    Roofing felt.
    1,950
    If I am not mistaken, Pergo requires a foam backing which is its own vapor barrier? Would a felt layer under the plywood still be advisable?
