    Feb 2014
    Default Hole in basement wall
    Our new house has a basement leak and when we tore down drywall to investigate, we discovered a 3 inch hole in the wall. It appears there used to be a pipe or something there. It most likely didn't start leaking until a downspout in that corner broke and all the water from the roof started pouring into that corner.
    Would Hydraulic cement be the way to go to repair this?
    3,188
    Default Re: Hole in basement wall
    Clean it very well and use fence post setting cement.
    Dec 2013
    Montreal Canada
    342
    I would go with Hydraulic cement and try to rough up the interior of the hole as much as possible so that it gets a good foot hold.
