    Feb 2009
    Question Moving baseboard due to settled hardwood floor?
    We're getting ready to paint our future nursery and have two questions. Our home is 54 years old and the hardwood floor has settled a bit, leaving gaps in places between the baseboard and the floor. I would like to remove the baseboard along one wall and move it down to cover the gap (about 1 cm).
    Question 1 - Is this a bad idea? What I mean is, are we just covering up a problem with a band-aid type fix? The house was deemed structurally sound when we purchased it last June.
    Question 2 - What is the best way to remove the baseboard without damaging it or the plaster wall beneath? There seem to be 3 nails in a vertical line about every 16 inches along the board - in line with studs?
    Thanks,
    badger
    Default Re: Moving baseboard due to settled hardwood floor?
    Instead of removing the baseboard, which will most assuredly damage the wall and likely the baseboard too, you could install a base shoe to cover the gap. The shoe can either match the floor or the base (if you have painted base ). It would be quick and easy to install. Shoe is generally a piece of quarter round or a slightly taller molding with a bullnose on the top corner.
    Feb 2009
    On the areas with a 1 cm gap, would I have room to nail the shoe molding to the baseboard?
    6,062
    Yes, You can get shoe moulding that is 2 cm and wider.
    I posted a response, complete with pictures, but unfortunately it seems that any post with an image linked to it must be approved by the admin. Hopefully it will be posted tomorrow.
