Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Default Re: Definition of an AB Box
    The only thing I ever heard called an AB box was a switch box for the television to switch from signal from cable back to the antena on the roof for when the cable went out.
    I guess that would make an AB Box a box containing a SPDT switch.
    Maybe you had a 3-way (two switch locations) for the light fixture. Don't know what that has to do with the lamp socket, if a lamp or bulb burns out replace the bulb.
  2. #12
    Baltimore, MD
    76
    Hmmm.... Do they make one of those that throws BOTTLES ?!
  3. #13
    7,238
    Quote Originally Posted by xyxoxy View Post
    That would be against OSHA regulations! You're lucky we could get a can version approved.
  4. #14
    Eden, NC
    285
    Wink Re: Definition of an AB Box
    I used an AB switch to set up my television vs the vcr and dvd and at that time a video disc player. The television was on one side of the switch (A)and everything else was connected to the (B)side of the switch. Depending what I wanted to watch I just used the appropriate switch. Basically, an AB switch is just a "splitter". Hope this helps.
    Calcats
  5. #15
    Feb 2009
    693
    Ah!............. An Anheuser Busch box!
    Good call Jack, Good call.
    Yes, I think it could be used with other circuits as long as it does not overload them.
    Thank goodness we are getting to the bottom of this!.......... Ain't the internet great? The power of many minds working in unison.
  6. #16
    5,842
    No, but a little help http://www.youtube.com/watch?v=fxfgxreJ75U
  7. #17
    Feb 2009
    693
    Will not say a word but....... LMAO!
  8. #18
    7,238
    That would even make it out of the box at my house before the girl forcible intrduced to my posterior!
    Funny stuff though!
  9. #19
    Eden, NC
    285
    The only AB switch I'm familiar with is really a "splitter" just like on your cable TV. I used one side of the switch to feed dvd, vcr, and video disc recorder into one TV. The other side of the switch was for feeding cable only to 2 TV's at once. Hope this helps.
    Calcats
