    Feb 2014
    Default Low Pressure in Shower
    About a week ago while taking a shower the water pressure cut in half. What could cause this and how can it be fixed?
    Sep 2012
    Boston
    1,002
    Default Re: Low Pressure in Shower
    start with removing the shower head and cleaning out the screen. when you remove the shower head, you can turn on the water and let it come out the pipe. if you get full pressure with the head off then the head has silt in it. if that doesn't work, you can remove and clean or replace the cartridge in the shower valve. if neither of those work the problem might be more serious and you'll have to call a plumber.
    7,762
    What's intriguing is the fact that the water pressure suddenly dropped to 50% the previous pressure.
    But first try cleaning the shower head.
    What kind of pipes do you have?
