Results 1 to 10 of 11
    Oct 2007
    16
    Default Gas fireplace ignition
    I have a gas fireplace with a pilot light. The gas is turned on and off by a light switch on the wall. The switch stopped working and I have replaced it several times with a standard light switch I got at home depot. It works for a little while, and then seems to short out.
    Am I using the wrong kind of switch? Or could there be a problem with the wiring?
    Thanks for your help.
    Default Re: Gas fireplace ignition
    Your set up resembles the old floor/wall heating systems so many old homes used to have. A simple "heat only" thermostat is all you need to close a circuit that opens a gas valve, and viola - your fireplace comes on with the help of the pilot light.
    Still having problems? call a plumber.
    May 2012
    137
    There is a name of the manufacturer on the valve body - mine is Rosschild or something like that.
    I am having the same issue with mine, but the Google-searched ****** docs say to take a multimeter and test leads/contacts on the valve body. They even have a diagram of which to check and nominal readings.
    Dec 2013
    Montreal Canada
    391
    If you have a standing pilot and the flame goes out i would suggest changing the thermocupol . this will resolve most issues with a standing pilot burner. If this does not work then change the gas valve.
    Jan 2011
    Columbiana, Alabama
    843
    I agree with all the responses but what the OP said has me confused.
    Does changing the standard single pole wall switch really fix the problem? The unit load should be very light and the switch should last a lifetime, unless we're talking about a 1.5 HP fan.
    In fact the load my be so small that something like an occupancy sensor may not work.
    BTW if the system works on Butane not Propane it may simply be too cold outside to develop enough vapor pressure to supply the heater.
    Mar 2014
    104 monmouth way ,Clifton Park, NY 12065
    13
    I too have doubt on changing only single pole wall switch really fix the problem.
    6,115
    It may be a low voltage circuit. Switches can fail when used on low voltage due to oxidation on the contacts with not enough voltage to keep them clean.
    May 2012
    137
    I had problems with mine, too, but I had an electrician come out and he didn't see anything wrong. While he was there, I flicked the switch in rapid succession and it started working again.
    The troubleshooting matrix I found ****** for my igniter actually suggested that...
    Jan 2011
    Columbiana, Alabama
    843
    Good point Jack, the standard SP switches have tungsten contacts which can drop a lot of voltage.
    Maybe a higher quality switch would help.
    2,743
    If you an find one, some old "silent" wall switches used encapsulated mercury vials in a sealed tube like you see in old mechanical thermostats. One of those is best for low-current applications but it no longer meets code because of the mercury- you're on your own if you go there.
