Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Dec 2013
    New Hampshire
    27
    Default Re: blow in cellulose or take down plaster and use fiberglass insulation?
    Keith, as to the math of how to get a 50% reduction of fuel by insulating walls. Von-steuben only said the walls were uninsulated to begin with not the entire house. Walls are often the last place to be insulated. If the baseline is a house with a well insulated attic, decent windows, and the major air leaks sealed up a 50% fuel drop shouldn't be that much of a surprise for blowing cellulose in uninsulated walls.
  2. #12
    Tennessee
    1,767
    The math still does not work. Uninsulated wall have an R-value of R-4 to R-5. This is due to having two surfaces with some value of insulation and air trapped between them. The studs add to the R-value because they are themselves good for about an R-4.4 and make up about 10% or more of the wall.
    If you fill the walls with cellulose, the cellulose itself is about an R-11, but because of the studs making up 10% or more of the wall and lateral conduction of heat by the two surfaces, the actual R-value of the whole wall drops to about R-10. So the best you could hope for is a 50% reduction of the heat lost through the walls. For a total heat loss to be reduced by 50% and the walls totally responsible for that, then there would have to be absolutely zero loss through the attic/roof, windows, doors, floor and infiltration.
    Adding insulation to an uninsulated ceiling is far more effective than adding insulation to an uninsulated wall. An uninsulated ceiling has an initial R-1. Adding just R-19 reduces heat loss through the ceiling by about 95%. Going from uninsulated to R-30 reduces the heat loss by about 97%. Going over R-30 is past the point of diminishing returns where the ROI (return on investment) is not justified. Bear in mind that the typical uninsulated house losses about 40% of its heat through the ceiling so adding R-19 to the attic means a savings of about 38% (.95x.4)
    Please do not misunderstand me on this. I do believe that even though insulating the walls does not give as good a return as insulting an uninsulated ceiling/attic, it still is worth doing and will pay for itself on a reasonable horizon. But doing just the walls will not cut your heating bills by 50%, even if the rest of the house is well insulated, weatherstripped and energy efficient windows are installed. But when the other stuff is done, then doing the walls is a very good idea and it will save some money. I just don't like people being disappointed when the savings aren't as big as they thought.
  3. #13
    Feb 2014
    southeast washington
    We had cellulose blown in our 1928 bungalow walls and had a significant improvement although nowhere 50%. While looking into the costs we discovered that our local utility services provided financial rebates or credits which greatly reduced our out-of- pocket expenses. Also the insulating contractor was very helpful in pointing out potential tax credits we might have otherwise overlooked.
  4. #14
    Feb 2014
    Rhode Island
    Some older wiring is only sized for open air meaning it will overheat if insulated. It is a good idea to consult an electrician before blowing in insulation.
  5. #15
    6,690
    Quote Originally Posted by durrock View Post
    Excellent point to consider.
