Results 1 to 8 of 8
    Jan 2014
    Default Transformer buzz vibrating my walls to death.
    My wife and I bought this house in June. We had some electrical work done, some of which involved relocating where the lines came to the house. The work that was done is great except for one thing. The cold has been causing a hum in the transformer on the pole across the road which vibrates along the wires and into the pipe that holds them. It is louder than the heater, louder sometimes than the alarm radio even and it keeps us up late and wakes us in the middle of the night. Is there something I can do without calling the electrician back to mute this noise? Some insulation I can fill the pipe with or foam I can put around where it is mounted?
    Oct 2012
    Houston, TX
    319
    Default Re: Transformer buzz vibrating my walls to death.
    Have you tried calling your power company? If the buzz is on the pole, it's their issue.
    7,344
    That's right, report it to your power company.
    2,478
    If the transformer is buzzing, it may be because of an overload so the power company will want to know about it.
    On your side of things, the lines coming to your house are supported by the 'traveler' , or the bare ground, so the current-carrying wires are not strained. How and where it's attached will matter, and you may need to relocate where that force is being applied, or reinforce that part to dampen or eliminate wall vibrations which are amplifying it. Technically, the power company is responsible for the lines up to the output side of the meter, but they're not responsible for the parts which are carrying those lines. They may or may not want to do anything for you inre the noise but you can ask them anyway.
    Without being there to see I can offer no more than that save to say that this is not something I've heard of before, nor can I see how anyone could have anticipated it when changing the service entrance. I learn new things here on these forums all the time myself too!
    Jan 2011
    Columbiana, Alabama
    792
    I don't have anything to add to the great answers so far. I too can't understand why a wire would transmit mechanical vibrations all the way across a street.
    I have seen many noisy street lights.
    1,902
    Have you ever made a telephone out of two tin cans and a string?
    If the transformer is buzzing or vibrating at an audio rate, then it has to be replaced. There are regulations on the allowable noise level a transformer can make.
    But the hum may not be coming from the transformer and I suspect that it isn't. You didn't have the noise before the electrical work but you do now. I always suspect the last thing done when a problem shows up right after. You could have a bad connection on the buss bar in your distribution panel.
    I had this happen to me, turned out the main breaker was not making good contact with the buss bar and it eventually caught fire. The fire was limited to the main breaker and a couple breakers next to it so no structural damage. I replaced the buss bar and the affected circuit breakers and all has been quiet since.
    edit: one more thing, if the noise corresponds to local wind velocity, then the wires could be just too taunt. This would happen if the new location was a little further from the pole and the electrician just pulled the wires a little tighter instead of running new wires.
