    Jan 2014
    Default insulating over attic floor boards
    Hello all, new member here. I have a 1939 house that has 6" joists with loose rock wool insulation then wood board flooring. Can I roll R30 or R38 batts insulation right over the floor? Will the air gaps in the loose insulation cause problems? I don't really want to remove the flooring in fear of cracking the plaster ceilings (lots of labor too). The house does not have soffit vents if that helps.
    Default Re: insulating over attic floor boards
    You can roll insulation right over the boards. To get a tighter fit, you can roll half the thickness in one direction and half the thickness in the other direction.
    Or just use blown-in which will allow you to work in the attic when needed.
