    Jan 2014
    Default System 2000 Reset Button
    I recently bought a house that has a not-terribly-new System 2000. Right at the moment I have hot water but no heat. There is a sticker on the unit that says "Press reset button on relay once." I'm clueless about anything mechanical. Am I supposed to know what and where the relay is? I don't, nor does the manual indicate where it is. In short, can anyone help me find the reset button on my system 2000?
    Thanks much,
    Gary
    Default Re: System 2000 Reset Button
    The reset button is on the primary control. System 2000 uses only standard oil burners, nothing OEM.
