    Default Removing slate tile from a basement floor
    I have an 80 year old house and the basement floor has slate tile. I need to remove a number of these tiles so a water management project can be completed in the basement. I am attempting to find the best way to remove these tiles with minimal damage so that I can reuse them.
    3,158
    Default Re: Removing slate tile from a basement floor
    Its going to be very slim chance you can re-use any of them.
    If you want to try, go at them with a thin trowel and steel hammer as close to perpendicular to the floor as possible.
    7,762
    If there is grout around your slate tiles, try to remove the grout first. Then use a wide chisel, or a putty knife and a hammer to pry under the slate.
    I also don't think you can save the tiles that come out. Slate is brittle and the tiles will most likely break.
