    Jan 2009
    Bristol, TN
    21
    Default Repair a hole in a hollow core door
    I have a hollow core door that my daughters "puppy" to a hole in. The hole is approx. 6 X inches. I have a product called Rock Hard. Will this work to repair the hole????
    7,867
    Default Re: Repair a hole in a hollow core door
    Take what you are paid per hour of employment, multiply that number by a minimum of 4 hours, what is the total? On top of that, you're going to have a crappy looking door patch that is likely going to crack due to movement through normal use of the door.
    A new hollow core slab will set you back maybe $40, in less than an hour, you can have it installed and be done with the whole thing.
    My vote is to do it right, replace the slab and be done with it. Way easier and cheaper in the long run.
    5,998
    Ditto to Spruce's post.
    7,637
    Have the puppy trained, or you'll have a lot more fixing to do.
    6" hole on a hollow door is too large to fix to make it look like "new".
    240
    While i agree with the others i will add that you really want a project to do, it depends on the finish. If its painted to a smooth finish then you have a chance. Using a sharp utility knife cut out the damaged area, fit some blocking into the hollow part so it overlaps the new opening around each edge and screw it in place using short screws. Glue and screw a new patch on top and use wood filler to sand it smooth. Its a tedious process but if you're like me and invite a challenge then go for it.
    7,637
    Quote Originally Posted by dcalabro View Post
    That's the right way of doing it.
    I just filled a hole in a hollow interior door in a remodel job, it was 2" wide. However, a 6" wide hole is too large and too time consuming to mess with.
