    Jan 2014
    Default Need help! Current shower needs a taller door!
    I just moved into a new home and want to install a bathtub door for our tub/shower. The walls to our shower are relatively newly installed acrylic panels. Our home has low ceilings (below 8 feet) and the panels in the shower are super low - without touching the current set up, we would need a short door (55-56 inches) and i feel like my husband will have to duck every time he walks in and out. I would like to install tiles above the panels to the ceiling to allow the accommodation of a taller shower door and also in an effort to brighten and "elongate" the space. (We currently have a shower curtain hanging on a tension road (left by previous owner).) My concern, however, is that the tiles available are slightly thicker than the acrylic panels themselves, making a seamless shower door installation theoretical tricky. Is there anyway to successfully execute this project and even out the panel and tile? Or will we need to replace the panels and skip out on the tile? Any info is greatly appreciated!
    Sep 2012
    Boston
    993
    Default Re: Need help! Current shower needs a taller door!
    install the tiles, as think a tile as you want, and get a seamless shower door. they have to cut the door to fit no matter what so notching it around a protruding tile is not a big deal for a custom shower door company.
