Results 1 to 9 of 9
    Sep 2013
    56
    Default Caulking the Bathtub
    Hi,
    I've been attempting to re-caulk the bathtub in my "new" house for the past couple of weeks. I'm running into a problem, though, with the caulk separating from the tub in places. The only part that needed to be re-caulked is the area between the shower walls (an inserted shower...not tile. Not sure what to call it) and the tub itself. I cannot figure out what is causing the caulk to separate. Below is my process, in detail. Please offer suggestions.
    I sc****d off the old caulk with a putty knife and razor knife. There were 3 layers of caulk, the top layer being very hard and brittle. It took just over an hour to get it all off, but I made sure I got it all. I ran the razor knife along the tub and shower area to get any remnants.
    I vacuumed the area and allowed it to dry until the next evening, about 20 hours.
    I used a caulking gun and caulk for bathrooms and kitchens. The tube of caulk said to let it set for 72 hours before exposing it to water. I waited 82 hours.
    Within a couple of days, the caulk had separated from the bathtub in places. So, I stripped it all off again, vacuumed, and let it dry until the next evening. I purchased a different tube of caulk (the kind that doesn't need a gun), and caulked it again. This caulk said to wait 24 hours, so I waited just about 2 days.
    Again, it separated. I am now understanding why the previous owners put 3 layers of caulk on the tub. They probably had the same issue.
    What could be the problem?
    Thanks!
    Default Re: Caulking the Bathtub
    What caulking (name brands and types) did you use?
    Sep 2013
    56
    The first one was DAP. The second one was ACE Hardware.
    Try a product called magic seal trim instead of caulking.
    2,737
    Wash the ares with TSP first- it cuts soap scum better than anything.
    8,065
    Quote Originally Posted by Mastercarpentry View Post
    Agreed, the surfaces must be squeaky clean for caulking to hold well.
    Sep 2013
    56
    Thank you so much! I will definitely try it out. I have a kitchen sink to re-caulk, too. Heck, while the caulking gun is out, I might as well just work on the other bathroom shower.
    8,065
    Quote Originally Posted by Loreen View Post
    Only do one bathroom at a time, you don't want to disable both showers at the same time, for a couple days. It's a real pain not being able to use your bathrooms when you need to.
    Spruce is right, it's a pain not to be able to use your bathroom when you need to ... unless there's a gas station around the corner.
