    May 2009
    Default Raised Bed vegetable garden
    What is the best material to use to construct the raised bed. Standard lumber will rot after 5 years and I'm concerned about composites.
    Oct 2007
    175
    Default Re: Raised Bed vegetable garden
    Redwood, cedar, cyprus and teak are all naturally rot resistant.
    Personally I've used pressure treated landscape timbers and they lasted about 12 years before the elements got to them, about the same amount of time for redwood... for comparison plain ol' construction grade 2x12's painted with a couple of coats of latex paint have held up over 15 years and still look good.
    8,004
    You are right to want to stay clear of chemically treated materials, and while composites are pretty stable and would last indefinitely, they are not without their leaching components as well.
    For all natural, as libcarp suggests, redwood, and other high tannin woods are naturally rot resistant and have a decent longevity in direct contact with the earth. I've got two made from 2x12 douglas fir that are holding up fine (it's what I had on hand ).
    If you want something more permanent, you may want to look into pouring cement or using cinder block or retaining wall block. Cement products will last indefinitely and in the case of the latter two, can be enlarged, reconfigured, or removed with very little effort.
    612
    You might be a redneck if.....
    You use old tires as raised bed containers laid out in the shape of a number "3".....
    8,004
    Quote Originally Posted by bp21901 View Post
    There's no "maybe" about it. The proof would be the buick skylark (that the tires came off of ) in the front yard being used as a planter and chicken coop!
