    Dec 2013
    Default 14" Medicine Cabinet between 14.5" apart studs
    My new recessed medicine cabinet is 14" wide but my studs are 14.5 to 14.6 inches apart. How should I make up the difference? Thank you.
    7,241
    Default Re: 14" Medicine Cabinet between 14.5" apart studs
    Center the cabinet in the hole, make sure that all edges of the hole are covered by the cabinet frame. Insert machine screws through holes in one side of the cabinet and drive them in until they just touch the cabinet. Do the same with the other side to secure the cabinet in place. You want the screws to be just tight enough to hold the cabinet from moving, but not so tight as to distort the cabinet. Done. Grab a beer and admire your work.
    1,720
    My favorite part of the job.
    Grab a beer and admire my work.
    Jun 2009
    332
    you could use shim screws.
    6,758
    Another approach is to use 1/4" strips as spacers on both sides of the cabinet.
    Use paint stir sticks (free at home depot and lowes).
    2,203
    The loose fit is intended because sometimes the framer gets a bit off and studs are bowed. It doesn't need to contact framing on either or both sides. Do as A.Spruce said, and feel free to substitute whatever beverage you prefer upon completion- just be sure to admire your work
