Results 1 to 10 of 18
    Aug 2012
    Northern California
    49
    Default Propane heaters?
    The smaller, classic type I like seems to only be available in the U.K. (I'm in California)
    Is this product available in the U.S.? One is the Provence Portable Heater, and the other is the Thurcroft Portable Heater (both by...Calor?) Maybe they're some code violation, over here? Or just too heavy to ship?
    This is their website.
    The back (with the door off) looks like this:
    5,824
    Default Re: Propane heaters?
    Those units are caravan or patio heaters, not designed for use inside.
    6,694
    Portable heaters like these, used indoors and run on LP or Kerosene, are responsible for a lot of deaths, through the years. Never use them indoor.
    Aug 2012
    Northern California
    49
    Oh dear.
    Thank you ..: )
    Maryland
    1,668
    Also known as salamanders in a different variation. Used during construction to warm a space enough to work. Not for a residence. Any fuel burning appliance will give off carbon monoxide if not vented.
    Aug 2012
    Northern California
    49
    Bummer.
    So then, I'm guessing the Radiance Vent Free Gas Stove is out, too?
    This is turning tragical...
    1,643
    There are some gas heaters which are so efficient that they do not produce appreciable amounts of carbon monoxide -- instead, the byproducts of combustion are primarily carbon dioxide and water vapor. (Side thought -- what about a gas range? We use those indoors.) However, if used in a small, well-sealed room, the oxygen in the air can be consumed to unhealthy low levels. Only select a heater that includes an oxygen depletion sensor.
    For more information, visit http://www.ventfree.org/
    Maryland
    1,668
    No matter what they say about an unvented heater even with a low oxygen sensor, I would never use one in a living space.
    1,643
    Quote Originally Posted by ed21 View Post
    I hope you don't use a gas range in the kitchen.
    Maryland
    1,668
    Gas ranges run as a heat source are potential CO problem .
    I figure adding additional pollutants to the indoor air is never a good thing. The smell of chocolate chip cookies and Christmas trees excluded.
