    Jul 2008
    11
    Default Temporary Window Sash
    Hello All!
    I am planning on repairing, reglazing and repainting several old wood windows over the winter. I am looking for creative ways to fill the dead space in the window while I have the sash out. It will be cold and, obviously, I don't want it to be unsecure & empty for the two days it will take for the glazing and paint to dry.
    Any ideas are appreciated
    2,623
    Default Re: Temporary Window Sash
    It should be easy to measure and fit plywood in there. Rip strips to fit the sides to hold it, then use painters tape to seal it inside. This should hold you for a few days and the parts can be reused as-is on all the other windows of the same size when their turn comes. After all are done, the plywood might be useful in another project returning it's cost.
    Jul 2008
    11
    Thumbs up Re: Temporary Window Sash
    Thanks Phil! I am also going to look and see if I have an old sash that is the same size and just replace as I repair.
    I thought maybe there was something made for this.
    thanks for the reply!
    1,876
    As Phil said, plus you might want to back that plywood up with some rigid foam insulation attached with construction adhesive. Use some closed-cell foam self-adhesive weatherstripping between the plywood and the jamb to form an airtight seal.
    7,735
    For added security,use bolts and nuts to secure the plywood into a 2x mounted inside across the windows.
