    Nov 2013
    Default Want to build a FLOOD-ABLE first floor in a cold climate.
    Our house is built in the flood plain. Last year for the first time since the city was settled our home flooded. We are not moving, so we want to make our house flood-able. We are going to jack it up, fill in the basement and then build a ground floor underneith the main floor at ground level.
    If we should flood agian we would like to be able to just hose everything down and not have to throw out dry-wall and insulation. I was thinking of building with painted cinder blocks but there is the problem of how to insulate. We are often at -30 in the winter months. Any idea's on how to stay warm and flood-able are much appreciated.
    2,969
    Default Re: Want to build a FLOOD-ABLE first floor in a cold climate.
    Closed cell spray foam.
    Jun 2009
    328
    Look at insulWall ( ICF )
    You get a structural wall with the insulation included.
    You can apply many types of finishes.
    Inside use cement Plaster.
    Nov 2013
    Thank you Clarence, I have wrote the dealer here in canada
    Quote Originally Posted by Clarence View Post
