Results 1 to 10 of 14
    Tennessee
    1,776
    Default What's a chassis?
    I need to find some of that plastic material that we used to use on holes in a chassis to prevent wire chaffing when the hole was irregular so a grommet would not do. I don't remember the name of the stuff. So today I dropped into a Radio Shack hoping to find some.
    I asked one of the guys working there if they had any, he turns to ask his boss and she looks at me and asks "What's a chassis?" Boy did I suddenly feel old.
    BTW, anyone remember the name of that stuff and where I can get some?
    7,190
    Default Re: What's a chassis?
    I don't know what it is you're looking for, but if the hole is irregular and has sharp edges, you can use 1/4" drip tubing. Cut a piece the length you need to go around the hole, then slice the entire length of one side. Then, simply spread the tubing open and work it over the sharp edge. A couple dabs of Shoe Goo (glue ) or similar will hold the tubing in place.
    If you need something more rigid or larger diameter, then go to an auto parts store and pick up some wire molding, it is already split for you and it will conform to just about any shape you need.
    http://www.cpxinc.com/Portals/0/Imag..._0001_pic5.jpg
    6,736
    Plastic/rubber sleeves?
    2,969
    Make the hole nice and round if possible. then install a wire grommet.
    Dec 2012
    New London County, CT
    120
    I think it is called railroad track. Here is a link to one brand: Grommet
    1,661
    I've used the stuff that they sell in auto parts stores for protecting the edge of the car door.
    Columbiana, Alabama
    738
    http://www.abbatron.com/product_info...roducts_id=326
    Caterpillar Grommet
    [2692]
    Chassis Thickness Range: .042-.052
    Height:
    .190
    Length:
    25'
    Panel:
    .047
    Thickness: .047
    Width:
    .139
    http://www.radioshack.com/search/ind...w=gromets&sr=1
    Model: 64-3025 | Catalog #: 64-3025
    Assorted Grommets (31-Pack)
    Price:
    $2.49
    3.5
    (2 reviews)
    Read 2 Reviews
    Write a Review
    Package includes seven each of 1/4", 5/16" and 3/8"; five each of 7/16" and 1/2&...
    See the Full Product Details
    Free Ground Shipping on orders over $25 Details
    See All Available Promotions
    AVAILABILITY: ******: In-Stock Usually ships in 1 - 2 business days In-store: Find it in your store
    Add to cart
    Tennessee
    1,776
    Quote Originally Posted by Condoman View Post
    Thats it. I don't need a hundred pieces and certainly not at those prices. I think I will use the flexible wire loom or maybe I'll slit up some fish tubing instead.
    5,836
    It is also called grommet strips. You might try and find an old TV and radio repairman and see if he has any. Or try some of the electronic chat rooms.
    About the smallest retail you'll find is a 25Ft roll http://www.alliedelec.com/search/pro...x?SKU=70211348
    5,836
