    Nov 2013
    Default Reinforcing sagging first floor in 153-yr-old home w/19' joists
    The first floor of our 1860 home sags 2", according to a laser light shot from the side walls. I'm also seeing some corner cracking developing in the supporting bedroom wall on the second floor that lies directly over the center of the house, where the worst sag is measured, and the finished 3rd-floor attic room floor also sags a bit toward the center. It all appears to be related to the unsupported length of the joists.
    I do a lot of work on my own homes and would like to give this a shot. The obvious solution is to jack it up.
    Now, I've read where you have to check to see that the joists are flat against the foundation so you're not just jacking up the entire house or damaging your side walls while trying to correct the sag. The house is built on a stone foundation, and the joists appear to rest flat at all locations, judging from the view inside the basement, which has a poured concrete floor. So it would appear jacking it up is the way to go. At a minimum, it obviously needs to be permanently braced.
    The trick for this Harry Homeowner is that the size of the joists varies. As noted in the subject line, the joists are 19' long, inside wall to inside wall. (The joist spans vary from 16 1/2"-to-20" OC.) But the other dimensions vary considerably - from 2 3/4"-to-3" wide, and 8 5/8"-to-9 1/2" deep. The latter figure is my biggest conundrum because if I run, say, a 4x4 across three or four joists, say, 8' in from each side, jacking each up with two adjustable Tiger jack posts, I'm not raising the floor above evenly because of the varied depth of the joists.
    (The 8' mark for support is pure guess, as there isn't an ****** calculator for spans with (roughly) 3"x9" joists. I'm also thinking of killing two birds by replacing the temporary supports, once done, with supporting walls and turn this into a 3'-wide vertical storage space down the road.)
    The joist dimensions don't vary a lot, however. If I follow this course, do I just measure and notch so the depth of each beam along the area where my 4x4 would cross it is uniform?
    Another question: I don't know how thick the basement concrete floor is. All those original/remodel plans are long gone. So I'm not sure how much if any I should reinforce the floor under the jacks.
    Someone has tried to fix this before by running a beam perpendicular to the joists across the half of the basement most affected, and supporting it with vertical posts. But it's totally inadequate: the beam is 1 1/2"x5 1/2", the supports are 4x4s and those are notched at the top to support the beam. The load in the center is such that the beam closest to the center of the house (and the stone wall, parallel to the joists, that supports the center) is floating. Zero support.
    A structural engineer took a look and offered to fix the problem in a week - for $16,000. That's sounded pretty high and regardless is out of my hoped-for price range. In addition, everything I've read says to do this very slowly so the wood has a chance to "re-learn" a new shape. I'm willing to take the time. I did get something for what I spent for the engineer: He asserted that raising the first floor would correct the issues I've noted above that level.
    That raises another concern I've read about: I don't know what type of wood the joists are cut from, but it is old wood. Am I running the risk that the wood won't return to at least near-level (not expecting perfection by any means) and that I could inadvertently end up jacking up the sides of my house instead? Should I be satisfied to brace the floor somehow and not expect any change to speak of? The goal, of course, is stability. Doubt I'll end up playing marbles up there.
    So, yeah, it's quite the project. But the hardest part is choosing the right path. So, your advice and suggestions would be greatly appreciated.
    2,917
    Default Re: Reinforcing sagging first floor in 153-yr-old home w/19' joists
    Has anyone proposed simply sistering the joists with new lumber? You can calculate the deflection with any of the more modern (compared to your house) standard framing / sizing charts.
    Tennessee
    1,694
    If you put in piers to support the floor joists, you will have to cut out the concrete floor and put a footing in under the pier location, no matter how thick your slab is right now. You will need to put in piers too.
    You will want a beam running perpendicular to the floor joists on top of those piers. With three floors above, I would say that triple 2x10's or 2x12's with piers every 8 feet should do. That may be overkill, you would need a structural engineer to determine if you can go smaller. You also might need a structural engineer to determine if there are any point loads where the piers have to be located. I point load would be common in a post and beam house, but even with conventional framing, you can have point loads under a load bearing wall where ever there is a large opening in the wall, and where there are staircases.
    Next, instead of notching the joists, I would set the new beam horizontal under the lowest joist and shim the others to the same joist height. That is say your largest joist is a 3x9, then the next joist is a 3x8, add a 1" shim between the 3x8 and the new beam.
    Jack slowly and do not expect to get all the sag out of the floor. Those old beams are not likely to return to a flat condition. Do not expect to sister the old joists either, that will damage the floor above if you try to use a sister as a straightening structure. Sagging floors are just part of an old house. Your goal here should be to maybe get half the sag out and prevent any further sagging. You may not even get half of it out.
    As you get some of the sag out, you may also see a lot of cracks appear in your walls. Over the years as the floor sagged, the walls would have developed cracks, which would have been repaired by previous homeowners. When you jack it up, the walls will crack around those repairs as now there will be too much plaster at those locations.
    If you just have to have flat floors, then watch this seasons TOH where they are jacking up some Jersey shore houses because that is what you will be facing. The house will have to be lifted by the second story, the whole floor ripped out and all new joists, beams and flooring installed, and that will probably cost a lot more than $16k.
    May 2012
    137
    A structural engineer sees things differently than someone who is untrained.
    They also understand cause and effect.
    Get a couple more estimates from professionals and reley on them to do the fix.
    You may cause more damage than what is there now because of your inexperience.
