    Jun 2013
    Default Help identifying old door knob
    We just finished a remodel of our old 100yr old home and lost an interior door knob.
    I'd like to replace it but have no idea what kind it is. I could use some help identifying the manufacturer, type, etc.
    Here are 3 photos https://www.dropbox.com/sh/sxmr5u8b8tcm3e3/U0SDldnBzD
    (I couldn't post them here because they are too large.)
    Let me know if you need more information (measurements, etc.). THanks
    2,916
    Default Re: Help identifying old door knob
    Looks like a fairly common style to me. Seen those many times. Shouldn't be all that hard to locate.
    Click here
    then
    Click here
    1,128
    It is a generic plain style,from 1900 and later, up to the post-war period, even. There may be a name (or monogram) on the lock itself, but you will have to pull it to see it. If a monogram, they can be readable of not.
    The knob would have been any number of styles, just not Eastlake/Victorian, because it's later.
    Casey
    1,736
    Most urban areas have restoration salvage yards that save old architectural items and hardware. Those knobs and style of backplate were around for decades. They usually had a square, threaded shaft upon which the knob would thread until it was snug to the backplate. They normally would have two set screws which would then be tighted until they snugged up against the squared shaft. I would be surprised if they are not available somewhere ******.
