    Nov 2013
    Default prune/undercut evergreen tree
    We have two huge evergreens in our front yard. The previous homeowner pruned/undercut one of them as it was growing into the driveway. Its lower branches now sag slightly as expected.
    We're thinking about undercutting our other tree but are concerned that this isn't the best method. I've also read that it's best just to cut them down.
    Any advice?
    Thanks!
    2,360
    Default Re: prune/undercut evergreen tree
    Depends on the look you want to live with.
    Let the missus decide.
    1,159
    I generally like the look of evergreens that grow from the ground, but if the need cutting the can be limbed up as desired. Just cut the branches to the collar next to the truck. Don't use a sealer on the cut.
    If they are white pines, cut them down before they fall or break.
    If they have overgrown the yard you can remove and replace if you want. Big trees aren't cheap to take down.
    6,480
    Go ahead and cut the limbs as desired, just know that evergreen limbs won't grow back, so whatever you cut is gone for good.
    Nov 2013
    Redondo Beach
    This work really is too much trouble.
    1,159
    I don't know your point. Then rent an apartment.
