    Oct 2013
    Default Infilled exterior door
    Hello,
    my house has an exterior door that was infilled. There was a large amount of air coming in from the exterior where it was infilled, so I decided to open it up to see what the problem was. I found out that no air sealing was done which explains the draft, but I also found out that the old wood threshold and sub-sill are rotten. I can see through to the top of the foundation. See pictures here: http://imgur.com/a/wM9Aw (forum won't let me post pictures). How would you go about fixing this? I'm covering it back up, so it doesn't have to be pretty.
    Thanks,
    JR
    2,737
    Default Re: Infilled exterior door
    Rotted wood is to always be replaced, even where it's not visible. You need to remove and replace all the suspect wood for structural reasons. Try poking a flat-bladed screwdriver into the wood- if it goes in then replace the wood. If it only dents it a little you can leave it if there are no other issues involved.
    From your photos I can see the extent of the rot. As Phil mentioned, you will have to clear all damaged wood first, before you can continue.
