Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    3,201
    Default Re: Hot Water Heater Emergency Temperature/Pressure Valve replacement
    I did a google image search for exploded HWH's and found only one. If this were a more common occurence, there would be many many more.
  2. #12
    Houston,
    There were more than 1 case of water heater explosions in the history of tank water heaters. The Santa Monica explosion is not on google - does it mean it never happened? Not every case is on google I guess.
    Like smoking near a gas pump - chances are that nothing will happen, still we all prefer not to smoke while filling up.
    Why take a chance if a new T&P valve is less than $10?
  3. #13
    2,743
    Houston,
    This exactly. The one I saw isn't on the net because it happened in the late 60's and they had no insurance coverage and were where no building inspections were done so there was never any documentation created, just several blown-out walls on the inside and a huge one (about 15 feet wide) in back. Had anyone been home they would have been dead. So yeah, test it and replace it.
    The odds are in your favor without testing but you're betting your life- do you really wanna do that?
  4. #14
    Dec 2013
    Montreal Canada
    387
    A true horror story:
    A "plumber" replaced a large water heater in an apartment building in Santa Monica a few years ago. The new water heater came without a T&P valve, so he plugged the hole tight. Subsequently, the water heater blew up very shortly after that, killing 10 tenants.
    Moral of the story: don't tamper with the valve and make sure it works properly.
    He was not a real plummber.
