    Oct 2013
    Default Sunroom Insulation
    I have a glass and alluminum sunroom that is open to the interior of the house and would like advice on how to insulate the glass sunroom.
    6,312
    Default Re: Sunroom Insulation
    Usually aluminum and glass sun rooms are not insulated. If you had a framed sun room, insulation would have been no problem.
    Feb 2013
    17
    If its the glass area where you are trying to reduce heat loss, you could try using insulated/lined d****ries. However, you would not have any sun coming in. The other area to insulate is the ceiling above the room. If its accessible you can use standard insulation.
    Bruce
