Thread: Hardwood floors
    Oct 2013
    Default Hardwood floors
    I sanded floors with a drum sander-20 grit paper--too aggressive. Now I have blonde skid marks all ovr. I sanded with orbital 60-80-100 grit. I plan to use a water based sealer and stain, then water base polyurethane. Will these skid marks blend in OR do I need to re-sand to even out? If so what grit to remove these skuffs.?
    2,969
    Default Re: Hardwood floors
    I fear the difference between 20 and 60 was too big a step. Are there grits available in between? If not then lots of 60 until they disappear.
    Oct 2013
    Thank you for your answer. I'll get started tonight.
