Results 1 to 10 of 11
    Mar 2013
    WI
    112
    Default waste pipe from toilet sits higher than floor level-ideas?
    A toilet waste pipe in my rental unit sits about an inch higher than the floor surrounding it. This is my wife's old house. About 10 years ago my wife had somebody build a "pedestal" for the toilet out of 3/4" plywood to make up the difference. The toilet keeps coming loose now. I replaced the bolts and wax ring about 1 year ago and it's loose already.
    Is there any better way to deal with this besides replacing the old metal waste line or the entire floor/sub floor,which are both still in good shape?
    6,762
    Default Re: waste pipe from toilet sits higher than floor level-ideas?
    I assume you're talking about the floor flange which sits on top of the drain. If that's the case, the best solution is to lower the flange. You need a plumber for this.
    Mar 2013
    WI
    112
    Yup,the flange sits too high.
    I was hoping there was a fix I could do myself.
    South*East
    1,227
    What size and type pipe do you have? If I had these questions answered I may be able to help you with lowering the flange.
    John
    Mar 2013
    WI
    112
    Cast iron,I believe it's 4".
    6,762
    I don't know how good you are doing a thing like this. If you don't feel 100% sure, call a plumber, it will be money well spent. And you'll get rid of the pedestal.
    You need to remove the existing flange, expose the drain and place a new "push in" ABS flange, the kind that you can tighten in place with the provided screws.
    1,675
    Step 1: Use an angle grinder to bring the pipe flush to the floor.
    http://www.harborfreight.com/heavy-d...der-91223.html
    Step 2: Then use an Oatey Twist-N-Set replacement flange.
    http://www.oatey.com/products/drains...-closet-flange
    This might not work if the pipe bends just below the floor.
    South*East
    1,227
    This is what DJ1 is referring to.
    http://www.what-if.com/SECURE/bruco/4-cast-iron-closet-flange-replacement-compression-abs-p-21.html[/url]
    John
    South*East
    1,227
    This is what DJ1 is referring to. Just be sure you screw it down to the floor.
    http://www.what-if.com/SECURE/bruco/...-abs-p-21.html
    John
    Mar 2013
    WI
    112
    Thanks for all the replies.
    This looks like something I could do myself,I'm fairly handy doing things like this. I just had never run into an issue like this,so I didn't know how to deal with the situation.
