Results 1 to 10 of 11
    Jun 2012
    81
    Default how to feed another switch from a switch question
    I have 3 switch box. 1 switch is a 3way, 1 switch is a 4way, 1 switch is a single pole. I need to take a feed from either the 4 way or 3 way to feed the single pole and another single pole in the box next to it. what wire and from wich switch to use for the feed?
    5,773
    Default Re: how to feed another switch from a switch question
    Not knowing what wires you have it is impossible to answer your question other than to say none of the wires on a 4-way are a constant hot.
    Jun 2012
    81
    gotcha- are any wires on the 3 way constant hot?
    this is a middle run box...
    feed comes into first box has this 3 way and a 4 way, then this box has the 3way a 4 way and a single then this 3way goes to the light......
    Jan 2011
    Columbiana, Alabama
    690
    Quote Originally Posted by gwilkrrs View Post
    The only place you can obtain power for another circuit is from the common (sometimes a black screw) on the 3 way in the first box. And, the neutral from the same cable as the hot.
    5,773
    You will need to test the common screw on the 3-ways with a meter or test light. One will have a constant regardless of the switch position, the other will be hot only when the light is turned on. You will still need a neutral to what ever the new switch is feeding.
    Jun 2012
    81
    THANKS! I will try this
