    Jun 2013
    13
    Smile Fine spray leak from copper pipes that connect to my water heater
    Noticing that water is surrounding my gas tank, I checked for leaks and found out that it is above the unit. No drips, just a fine spray.
    It is a replacement Westinghouse that was installed two years ago. There is like a green paste on what I think is the affected area and looks as tho' something was taped (?) around it at one time, but, I can't be sure and can't find any tape-like materials around the tank.
    The leak is spraying in the area of the little hood at the top.
    Should I call a plumber now? On Monday? Or, is this something I can fix myself ~
    Thoughts? lol
    6,500
    Default Re: Fine spray leak from copper pipes that connect to my water heater
    It's always a good idea to fix a leak when you first notice it, because leaks cause damages, and they never get better with time.
    You might have a leak around the cold water in or the hot water out - both lines are under pressure. Since I don't know how much you know about plumbing, I can't tell you to go ahead and fix it yourself. A plumber will probably charge you for an hour or a visit plus parts.
    Jun 2013
    13
    Thanks ~
    I know enough about plumbing to be vigilant, recognize potential problems and then ask. But, I can thread a gas line for a stove. And, do it right! lol
    The water spray is cold. I don't see a shut-off valve any where.
    Should I shut off the main water or will it last til Monday. Unless it's a super-emergency, I honestly don't think I can get any one here now or tomorrow.
    6,500
    The code around here says you have to have a shut off valve on the "cold water in" pipe.
    If you can't get a plumber tonight (and I don't know why), at least shut the water supply. No shut off valve on the cold side? shut off the main when you go to sleep.
    Jun 2013
    13
    Thumbs up Re: Fine spray leak from copper pipes that connect to my water heater
    I found it - It was quite a distance from the tank and obscured.
    Thank you so much!
