    Sep 2013
    11
    Default Cover old shed roof?
    We have an old house in Florida that has an old 10' x 14' shed built of cypress. The structure is solid but the roof is terrible. It's the old tar and gravel type that's been tar patched many times. I'm wondering if there's a way to cover this with something better without the work and mess of removing the old roof.
    7,241
    Default Re: Cover old shed roof?
    The right way is always the best way, and that will be to strip it down to the deck, repair any damage, then install a new roof.
    6,758
    About 10 years ago I had a job like this. The house had not 1 layer of rock roof, but two. What a mess.
    Anyway, we removed the two roofs, had a lot of cleaning to do, worked on the deck (replaced worn out water damaged plywood), beefed up a couple of rafters and did a complete roof job. Never had a call back.
    Listen to spruce, even on a tiny job like an old shed - do it right the first time.
