    Sep 2013
    Smile Beadboard joining to tile backsplash
    What is the best way to connect a beadboard backsplash to a granite counter. Also, how to connect the tile backsplash behind the stovetop to the vertical edge of the headboard.
    3,201
    Default Re: Beadboard joining to tile backsplash
    All tile gets caulked at the changes of plane or when abutting a different material such as beadboard.
    At the counter top leave a 1/8" gap and caulk it closed with silicone or latex caulk.
    ...And if the horizontal connecting line is not even or not level, hide the imperfection with a molding.
    2,743
    Finish the wood first (paint or poly) then use a 100% silicone caulk as latex caulking will get moldy rather quickly in this setting. Also don't set the wood directly on top the countertop, but at least 1/16 above it which will keep it from soaking up any moisture that may get under the caulking over time. I'm surprised that Houston Remodeler didn't mention "colorriteinc.com" as a source of 420 colors of silicone caulking, of which one is bound to give you a pleasing color match.
    3,201
    Sorry for the omission Phil, I must be slipping.
