    Sep 2013
    Question Protecting wire in a basement install like one on TOH.
    There's a TOH video about insulating the basement with polystyrene foam and then using furring strips to mount drywall to. TOH video
    What I'm wondering about is is there sufficient depth to protect the wires with only one furring strip depth? He doesn't cover how to secure the romex so it's deep enough and protected properly to code.
    Columbiana, Alabama
    698
    Default Re: Protecting wire in a basement install like one on TOH.
    Quote Originally Posted by J2E View Post
    The Code requires 1 1/4" between Romex wire and the edge of the framing so with a 1" hole in the framing a 2" stud is usually the minimum, to protect the wire.
    If run in electrical mettallic tubing (EMT) one might get by with a stud 1" deep. However, the minimum recessed box dept is
    1 1/2".
    Using a surface raceway system called "Wiremold" might be the most practical method. It's available at Home Depot, Lowes and all electrical supply houses.
