    Sep 2013
    Default More comfortable floor for basement playroom.
    We have a finished basement with a tile floor. We put some cork floor down that we got free from a friend. It was great, because the tile floor is always cold, and we wanted the room to be a playroom for our kids. The cork floor felt warm, and made a great floor.
    The problem is, the basement isn't completely dry. During a heavy rain we'll get a small amount of water on the floor next to the wall. The puddle seldom extends more than a foot from the wall. But it got the cork floor wet, which got moldy, so we ripped it up and threw it out. So now we are back to the cold tile floor.
    Does anyone have any suggestions for what we can put down for flooring to make it an inviting floor to play on? It has to be able to withstand a tiny amount of water without getting ruined or moldy. And I'd really like it if I didn't have to tear it up to let it dry out if it gets wet.
    I realize the best course of action is to fix the water problem first, and then install a floor, but because of expense, that really isn't an option. If I were going to grow old in this house I'd consider it, but I will only be here another 2 or 3 years.
    Thanks for any suggestions.
    Default Re: More comfortable floor for basement playroom.
    If you don't want to do it the right way, because it costs too much or because you plan to stay there 2-3 years, then do it the wrong way: install cork again. When it gets wet, lift it up and let dry before new mold appears.
    I just don't like the idea of small children playing near mold.
    1,950
    There are basement sub-floor systems which protect against moisture and even wetness on basement floors. check this website out: www.dricore.com. This system is 3/4inch plywood bonded to a plastic surface which acts as a moisture barrier and holds the plywood off the floor. It consists of 2x2 interlocking panels upon which your floorng can be placed.
    I have seen this system at Home Depot. A further benefit would be that it would also isolate the flooring from the concrete, making it even more foot warm.
