    Sep 2007
    Default Improving Steam Radiators
    I have single pipe steam radiators that I am having refurbished. While they are out, I want to install some reflective materials on the wall behind the radiators to help with radiant heat into the room (versus warming the outside wall).
    What material should I use? I have seen using some unpainted sheet metal as well as some ISO board w/ a reflective coating.
    Also, is this worth the effort?
    Thanks!
    443
    Default Re: Improving Steam Radiators
    Yes, any reflective material will reflect a lot of the radiator's heat so more of it gets into the room.
    I like the idea of using ISO board.
    I suppose it has to be balanced with maintaining a good appearance in the room.
    There are 2 ways a radiator emits heat into a room:1) by convective heat, where the hot surface of the rad sets up circular air currants to naturally distribute heat throughout the room; 2) by radiant heat, where the rad's radiant wavelengths are emitted (much like the sun's rays) until they strike something & give up their heat.
    The radiant portion has the ability to be reflected back into the room.
    These are very popular in the U.K., where they claim 70% of the back side of the rad's heat is wasted thru the wall without a reflective panel.
    They are making them over there with heavy duty aluminum foil wrapped around cardboard & pasting them to the wall.
    Google "radiator reflective panel" for numerous sites.
    http://www.ecofirst.net/radiator-reflectors.asp
