    Sep 2013
    Default Old lock set hole
    I have a old doors I wish to use but the locksets are only 2" from the edge and can't be reused. How can I redrill over the existing hole to handle the newer locksets.
    6,053
    Default Re: Old lock set hole
    You need to either install a plug the same size as the existing hole or inlayed patches on both sides.
    You can get router inlay kits from any wood working store. Here is a link to a video demo of router inlay www.woodworking******.com/2007/03/05/podcast-14-router-inlays/
    Inthe link above replace the ****** with o n l i n e with out the spaces
    1,901
    You can also use a repair/reinforcement shield.
    http://www.amazon.com/s/ref=nb_sb_no...ine+reinforcer
    I didn't say it would look pretty.
    8,065
    You say the existing locksets are 2" from the edge, but this is irrelevant, what is the center line of the existing hole? The reason that this is important is that old locks tend to have a smaller diameter hole, so adjusting a small hole for a new lockset may be possible without any modifications to the door.
    Current locksets use a 1-3/8" set back for interiors and 1-3/4" set back for exterior doors. Set back is the distance from the edge of the door to the center line of the lockset.
    To redrill a door, you make yourself a jig by making a "horseshoe" of 1x6 over both sides of the door and the edge. You clamp this horseshoe over the existing hole, mark your setback from the edge of the door. Drill the new hole with the recommended sized hole saw, which is generally 2" (resulting in a 2-1/4" hole ), verify the requirements of the new lock/handset before you drill.
    1,901
    Spruce, I think you mean 2+3/8" and 2+3/4", respectively. The thickness of the doors is typically 1+3/8" and 1+3/4". I believe the hole for the lockset is 2+1/8" diameter.
    That is, the center of the hole is positioned according to these measurements. If you have at least 1+5/16" between the edge of the door and the existing hole, you can rebore 2+1/8" hole at a 2+3/8" backset without any problems.
    Spruce's horseshoe trick is to make something out of wood similar to the metal bracket I posted earlier, and use this as a guide for the hole saw to enlarge/reposition the hole. (It's not necessary to make the hole in the horseshoe before attaching to the door, but doing so will make it easier to align it to the door.) You may also need to enlarge the bolt hole; old style are around 3/4 or 7/8"; the newer ones require a 15/16" hole. (I think. You'll want to double-check the bolt hole measurement.)
    8,065
    What, is accuracy really necessary?
    Yes, you are correct, I did, indeed, mean 2-3/8" and 2-3/4" as the setback. I did say to verify the measurement requirements of the new lock sets, which also includes the diameter of the hole.
