    Sep 2013
    Question caulking a shower
    I need to remove the caulk around the bottom of my shower walls. Is there any type of chemical that I can use to make it easier to remove? I sc****d it off about five years ago and re caulk it due to mold, there is mold again.
    Default Re: caulking a shower
    Sorry, you'll have to do it again. There are hand tools to make your job a little easier, but basically, it's all labor.
    Treat the area with bleach and use mold resistant caulking.
    Sep 2012
    Boston
    1,002
    lastly, make sure that the crease is 110% dry prior to putting the caulk on. i sometimes use a hair dryer or heat gun to dry out the crease that you can't access with a rag or paper towels.
    Sep 2013
    Thank you so much I will use the hair dryer this time to make sure it's dry.
    3,201
    Be sure to use only 100% silicone. Not siliconized latex. Latex is mold food. You can order grout matching silicone in sanded or unsanded in any of 300 grout matching colors from www.ColorRiteInc.com
